Boring crashes into lower side
Hi Folks. Cant figure this on out. bar crashes into lower part or geometry. I have a file that works and does not behave like this but i cant figure out what the difference is or why this behavior. anyone know why i cant select a way to control where the bar goes? its not consistent from what the roughing is doing or follow the same geometry as the roughing,. Roughing doesnt crash in to the part. Its bigger than 4mb so i cant upload here. any suggestions?
I had that problem with boring bars hitting when I first started using Bobcam, I called support and was told that the issue was the software thinks the bar is too large to fit. So I just needed top change the rapid value on the feature page. Here is what I do.
  1. Go to the Feature page
  2. Click in the Material approach box
  3. Change the rapid Plane to a very small value.( Default sets it at .2000. So I just give a value of .01)
    I don’t know if this is your issue, but it’s worth a shot.
