You can specify a tolerance when initially creating a dimension, but once it’s created the value can’t be changed (via Entity Modify).
Thank you for this finding… we will get in handled in the next service pack!
Just an FYI, if you change the combobox to a different tolerance type, and then change it back everything will work. Seems to be something related to that status, so just wanted you to know the quick work around before the fix!
