Burny 1250 plasma problem
wont read any of the code that was already used on it once cant figure out if its a machine problem or a code issue can anyone look at this and tell me if the code seems odd not sure what the best way to post it for people to look at it if someone could let me know then take a peak
Is the file extension the same? When you say it won’t read the code: Do you mean it does not show up in the control to select it, or does it just not run, or error out. Can you give more detail about that?
