Hi all,
there is always the need to enrich existing G-code with additional actions (e.g. check cutter breakage after tricky passages or longer nesting task; halt the program to do measurement check; switch a signal to give operator a note to come to the machine; …). Doing this with “Edit Toolpath” would be possible, but it always gets killed if “Compute Toolpath” is done again.
Having an operation, that allows to insert own written G-Code would be perfect. So you can keep working on optimizing the whole flow without adding additional code each time in the generated NC file. Also has the advantage that the addition can not be forgotten
. I don’t have Mill-Turn so I don’t see it either. I think and hope it will be available for Mill 3 Axis / Lathe in the next version upgrade. I know the documentation could be more clear and specific in mentioning at what level of software (i.e 3 Mill 3 Axis, Mill-Turn or Mill 5 Axis ) these things are available and useable instead of sending you on a wild goose chase.
