When I choose ‘left’ for cutter placement, it automatically generates a post that cuts conventional instead of climb cutting. This is regardless of how and where I place the ‘start’ arrow. I am using V24. Any ideas as to why? Thanks!
Well then try right you should get what you want.
I stumbled on the necessary setting. These were not mentioned in the tutorial. I do have two other questions I hope you can help.
1)Mt Bobcad v24 will not post a cutter path using a tool les than .100 diameter. I tried .099, but it just will not post. It will generate the toolpath however.
2) When I try to verify the program, I get an error saying ‘No data to verify’. What am I doing wrong?
Thank you !!
