BobCAD referred me to their support page(which was ZERO help), so here I am…
Anyone have any info in regards to "Exception raised in calculation routine( cuts are empty! )?
It looks like there may be a potential issue with the amount of stock available for the advanced rough to cut.
On the Parameters page, try applying a user defined Top of job that is a small distance above your model so that there is room for the toolpath to be applied.
It could also be a similar issue with the boundary condition where the tool reaches the boundary before finding enough stock to machine, you can check the Options page and test the other Boundary options available (Center of Tool or Tool Outside).
