I have noticed lately that flatlands isn’t posting rapid moves anymore even though it is checked in the box to do so it just stays at the same feed rate…
Hi @brisian
I had a similar issue and sent in a ticket for it. The response from BC was to use the “Links” in Advanced UI mode for that operation, which you will need to have a Mill-Pro license.
The work around is in links check full retracts. Its a known issue that I believe is a pretty deep fix that I was told is being worked on.
ok i will try that right now. thanks
ok that worked thank you
The only problem is it retracts to your clearance plane every time which can be somewhat annoying, but it will eventually get fixed.
Glad it worked!
Hi
@MaxD400, @gmyers, @JasonBroderick, @Nizam
Will this issue and other known be fixed in a SP3 release of V36 ?
Thank you
