Hello guys,
when I print on my V25, is there an option to not show the green/red arrows of the X,Z axes?
Thanks!
Hello guys,
Thanks!
Go under file then setting, Under the Current Document tab go to Display then Axis X Y click that box off
Thank you for the prompt reply.
I already tried it, the X and Z lines disappear, however the green and red arrow stay…
Ok click the box for Show Gnomon should be right under the show axis box
Is it blue? maybe turn the USC Plane Display all the way down.If that don’t work I would look under systems. Iwas never a fan of V-25
I tried everything still can’t make it disappear. The worse thing is that in the past I could print without those arrows but don’t know how.
Thanks for the help anyway
Been a long time. But can’t you take the Show Axis X-Y and change the color from
black to whit or maybe yellow? I think if it’s the same color as your Background you will be good. If that don’t work look for the UCS migh be on system.
I tried everything unfortunately and it still shows. I’m attaching some screens of the menus.
It’s really a mistery considering one time I was able to print without those arrows…
Hi Saumur,
There is not a Show Gnomon in V25.
There is on that page in the newer versions to hide the X and Y arrows.
In V25, you could translate the drawing away from the axis.
That way you could print with fit to page.
