How do you ungroup tools in Bobcad Ver 35? We have been able to do this in older versions of the software.
I have read through most everything posted about tools and have not found an answer.
New features tells only about new features.
I haven’t found a list of what has been removed.
If it hasn’t been removed, would someone please give us the instructions to ungroup a tool so steps aren’t skipped that must happen before the tool is used again.
Thanks.
might you be looking for the operations list?
We are trying to get the post to stop jumping to the next operation with the same tool.
It seems to do this automatically. How do we stop that so it processes in the order programmed?
try moving your operations around in the operations list…you can drag and drop operations where you’d like…you can also group them according to tool and operation…
this is from V36…but V35 is the same…if you’ll notice the operations tab in the lower left corner…there you can tell it the order of which tools or ops you want to do,when…
I’m running V25 so not sure about newer versions.
Look in CAM TREE
Open CAM PART
Open MILLING TOOLS
Drop down to PART>
or DEFAULT>
Click on MACHING ORDER>
Of the choices (3 for PART>), (4 for DEFAULT>) available, I believe you want to check the
INDIVIDUAL FEATURE
That should complete everything for that feature using the tools as intended.
Hope this helps.
Is now BOBCAD-CAM is updated with a new version?
