MillingGuy (Harald), Many thanks for your help!
general, From what I have read & seen about “parameters” and “diagnostic”  areas of the controller, the ability to have 2 mills in the shop, with the exact same model of controller on each, and they possibly could have some significant differences in how they operate. It only takes 1 of those “bits” to be a “0” vs. a “1” to make a change.
Cabinetmaker, I started with the manuals that came with the mill, only to find that there was an up-dated list of “diagnostic” data that matched the “parameters” that I only found out recently by reaching out to the machine builder. The machine builder I have been working with, has been excellent, and I pray we will prevail, and the mill will accept g-code properly soon.
Just a short note about the direction how things are going, The machine builder has help enormously, starting with those fussy “diagnostic” settings.
We are working on the ATC to make it function completely proper with the correct setting on the Z axis location in “diagnostic” to confirm X20.6 is a 1 when in MDI keyed in; G91G30Z0.; that the head stops to make the “1” confirmed, at the location (+ - z) to accept toolholder from tool changer. Apparently, it’s necessary for the ATC functioning properly, so not having an error starting with the ATC. This is where I am at, just moved the “switch dog” to set that.
As for a Post processor, the machine tool builder told me, this mill can be used to “broach” using the “Z” axis, and my hope is there may be an existing PP to use.
Many, many thanks!!
