Greetings, I am in the process of learning to load & run programs in a 3axis Bed Mill with a Fanuc MO controller. I have had a 2axis CNC knee mill for several years. With this Fanuc I am using a post processor from “MillingGuy” that allows a 220v bolt on hi-speed spindle (to replace the BT-40), with collet system (so no toolholders, will be used, “touch off” (required for Z axis) each time tool is changed) to be used.
Where I am at is the sample programs I am using will not run all the way until the end of the program. It will stop at line 05 G01 Z-.125 F 57.5. The mill green light will be on, but will not do anything.
How can I get to understand why or to know what the reason is or know what to look for, so when I get the real part I can know how to fix or what is the workaround is. What are the things to look for, my hope is to set a “template” up for each mill, so less confusion.
This is the sample program:
O0100
(PROGRAM NUMBER)
(PROGRAM NAME - O0900.NC)
(POST - FANUC 0M)
(DATE - WED. 07/12/2023)
(TIME - 11:25AM)
(FIRST MACHINE SETUP - Machine Setup - 1)
N01 G90 G80 G40 G20 G17
(Machine Setup - 1-Feature 2 Axis-Profile Finish)
(FEATURE 2 AXIS)
N02 G00 G90 G54 X4.3732 Y2.2453
N03 G43 H01 Z.525 M08
N04 Z0.
N05 G01 Z-.125 F57.5
N06 X-.0537 F115.
N07 Y.2296
N08 X1.07
N09 G17 G02 X3.2494 Y.2296 I1.0897 J-.0938
N10 G01 X4.3732
N11 Y2.2453
N12 G00 Z0.
N13 Z.525
N14 M09
N15 M05
N16 M30
Many thanks in advance for any suggestions!
