I have forgot how to make line segments into a continuous line. I want the opposite of explode.
Hi David,
Use the CleanUp / Optimize function, found in the Utilites Menu.
Please use Cleanup / Optimize as stated above in your case.
However, I also wanted to provide more feedback if users are trying to reduce other line segments as well.
In the video link below, I first use Cleanup / Optimize as stated above to reduce the line segments of a line. However, if you want to reduce the entities of a circle (that has line and/or arc entities), use “Fit Arcs”. This will reduce the number of entities for arc entities as well:
