Hello All,
Recently I got a package of 21 parts, very simple machining, just the length of the part and hole locations were different. For the 3 operations I had to run I created a UCS for each op and use the UCS for the machine setup coordinates for each setup.
I saved the file as a template to use for the following parts. However, when I open the template file I don’t see the 3 UCS’s that I originally created, only the system UCS.
Is this normal or is there something I am missing ?
Thank you,
