Is there a way to make Bobcad default machine compensation to always on comp left/G41? Im using version 33
I would be interested if defaults could be set to G41 with machine comp off.
Also if thread milling would work using G41 and machine comp off, (BobCad won’t thread mill like this).
So BobCad is not really fit for purpose, maybe BobCad should fix all the issues with older versions before making new versions.
We have version 34.
In BobCAD, you can set default machine compensation to “On” and specify left compensation (G41) in your post processor settings.
thanks for the reply sameed21.
I’m looking in current settings and the posting tab. I don’t see anything in that tab about setting defaults for comp on. Are you talking about actually opening up the post processor I’m using in notepad and changing it there?
Hi Aarcher,
Have you tried the Save Defaults in the operations wizard, you can also set up your own user defaults template.
well I totally forgot that button was there. I’m gonna try that and I’m pretty sure that is gonna fix my problem.
