So I needs to speed up my thread mill SFM .I go under the stock material name I see Thread Mill change the number .Then I go back to the feature no change the only way I can get the number to change
was under General Feeds and Speeds . Looks like I may need to add a new Tool material for my threading tools.
Hello Eric,
Welcome to the forum! Did you make sure the select the “Tool Material” that you are using for that tool before setting up the SFM for the Thread Mill?
It should update the speeds and feeds in the feature as long as “Use System Feeds and Speeds” is checked off in the feature.
Yes I sent the problem to Bobcad they say it has something to do with the fact my threading tool is a single point. And will look into getting it fixed.
