What do you prefer with BobCAD ?.. dual monitors or wide screen 21:9
and have you tried both?
i just use a 16:9 24 inch monitor…seems to work well for what i do…
When the new UI came out, which is very good and appreciated, I got a 27" (16:9) monitor and it is very comfortable to work with. Below is the layout I work with.
When you say dual monitors, are you extending 2 monitors ?
Ya - extending one…interesting layout…I might try what you got going on, on the right…
Yes, I try to keep the things I use often readily available.
I use the Extending also, for some reason I thought that was one image stretched over 2 monitors
. Weekend is here, I will get some rest.
How did you get the smaller text size in the windows on the panes on the left and right?
I suspect its his windows display setting under “scale and layout”
