Hi Guys & Gals
My name is Keith. I recently down loaded a DXF file to BobCad software (I have V25) I tried Nesting the parts of the drawings and when I left click compute tool path the parts were put on top of each other so I redrew the parts with points on the lines then deleted the old lines and joined the points with lines and three point arcs but the nesting did the same thing what am I missing here? can anybody help me out?
Woodrocker, Welcome to the forum. You might want to check out the tool size. Without seeing your part, it might be that. maybe save to a cloud drive and share the link so it can be downloaded to test out for you.
DINO.bbcd (872.1 KB)
Thanks for the quick response Darren
There is the file i am talking about
Thanks Keith
Woodrocker, Good afternoon. The issue is with the slots on top of the dino’s head. The software is not letting us do common line cutting. I spread them out to .30 and it works. Also if you use a smaller tool, this will work without any changes. hopes this helps
Thanks Darren I will try that
