My Bobcam started not posting m08 an m09. If I change to a different post It will Turn coolant on and off. My coworker uses the same computer and his will turn the coolant off and on on the same post. Is there a setting that I changed accidently?
Figured part of it out. When I go to Current Settings > Machine Parameters and select customized coolant options to activate thru spindle coolant, than this post will not add any coolant.
If I was you I would copy your coworkers post to your computer. And machine
