any one have a link to a tutorial for converting a scanned item to a file I can machine a profile from.
I traced the image but haven’t figured out how to complete the process.
I’m using version 27.
Dave
If you have the part you want to machine in jpeg or other image format, you should be able to use BobArt to load the image and Vectorize it. Within the Vectorize function you can scale it to get the size correct. Then use the vectorized image to create a toolpath. You may need to do some touch-up of the vectorized image to create a closed path, or eliminate extra lines.
