The plunge lead function is rapid moving down into part instead of up off the part causing divots in part.
The ramp function works correctly, but causes a lot of extra time in the process.
Any ideas? Maybe the post processor is a little off on this function?
Can you see this happening in Simulation, or Backplot? What version software using what toolpath? Can you please provide a few more details for us.
Thank You
I’ve had this happen. Usually when switching from a rough cut to a finish machining process where the steps are bigger in some areas. You’ll have to change your Rapid Plane and the Feed Plain within the feature that is causing the problems. It adds a bit of time to the process but you eliminate that scary chirp you can hear across the shop…
Timothy
