Hi, I have just buy a Revopoint Mini 2 advance scanner with 0.02mm solution.
My lathe is an Emco Concept 155 mill turn with c-axle.
Does anyone here have a scanner or know a bit more about whether Bobcad can import STL files. Programs from Esprite must minimize the program code with a program generally called Reengineering. It would be great if someone who prints in a 3d machine and knows how it works.
My goal is to be able to scan small details such as gears, shafts and other things in mechanics that can then be produced in the lathe.
What do you think.
You can load .STL files into bobcad. But i have not done anything with 3D scanners hope to some day keep me posted on what you find out.
Thank you Erik, I load STL file to my mobile and it works fine. I do same in BobCad v30 and find the file in solid model but something was wrong.
The pictures- a car door don’t came up.
Maybe it is my grafic card.
The scanner is on the way and I will ask some youngster how now more than I do.
When I have more clue of this magic thing I will tell you.
I love these insights mate as I was looking for this only. Also as a new member I am loving this community so far Looking forward for more such discussions.
