I was just wondering if there is a way to move the Total machining time from the Sequence are or at the bottom. up
to the top or if I can add it to the Move so it’s at the top?
I just want to see it with out rolling to the bottom .
@Eric There is no way currently to move those parameters displayed around in the software. However, if you were looking to quickly check the machining time calculated, you can click the Toolpath statistics button from Milling contextual ribbon tab (it will be lathe or MillTurn based on your job type) which will pop-up the toolpath statistics dialog showing the machining time which will be very close to the simulation time if not exactly the same.
