Trimming two cylinder to fit at 90 degrees
Good Morning,
New to working with solids to make a 3D mold andI need to butt together two cylinders at 90 degrees. Cannot find a good solution to do this. Any suggestions?
I made a quick video that might help :wink:
Thank Alex. I’ll look through it in detail when I can but it looks like that is what I need.
Jeff
PERFECT! Thank you for the quick lesson and I’m sure others will benefit as well. It worked great!!
Thanks again,
Jeff
Hey Alex,
Your process was able to give me two right angled cylinders but a side effect of it is now the cylinders are no longer solid. How do i make them solid so that a mold can be made?
Jeff
Use the stitch command to make them a solid again.
Thanks Alex. I figured out my problem. I was not selecting the end caps of the cylinders to attached them to the cylinders themselves. Works great now.
Thanks,
Jeff
