V-Carve missing Operations
When I choose V-Carve and select geometry, nothing shows up for Available Operations in the Machining Strategy page. I am using a step file that already has the “engraving” letters in it, I can select them as geometry but can’t choose a tool etc. What am I missing?
I just created text in BobCad and I still do not get any available operations after selecting it as geometry.
So if you want to to do a 2D text use 2d Engraving. and for geometry select your text
For 3D for your Geometry select your solid, Machineing Strategy use Project Curves
and under Patterns pick projection courved as your text under Parameters give it a -.010 or something to make it cut into the part
V-carve is part of the BobArt module, if you don’t have BobART on your license you won’t have the V-carve tool path.
