V25, Lost Layer-UCS-Post Manager pane
I’m using V25 on dual continuous monitors. I drag the Layer-UCS & Data Cam Tree panes over to
monitor 2 to open up the drawing area on monitor 1. Somehow I’ve lost the Layer-UCS pane. it is
checked and shows as active in the drop down box when I click the blue area at the top of the main
screen view. I don’t know if I minimized it or moved it off the visible monitor screen or if it is hidden
behind something. Anyone else have a similar misadventure or a fix for my frustration?
The first thing I would try is to unplug monitor #2 video cable, this forces everything back to monitor #1 and hopefully it will re-appear for you. Move the window right in the middle of monitor 1 and then plug monitor 2 back in.
Thanks for the reply and suggestion. I tried but the UCS-Layer pane is still a no show. I’m getting the IT
folks to look at it and see what they can do. Thanks again.
