V38 2 Axis Lathe Rough Cycle Cutter Comp Not Posting
HI All,
We’ve just added 2 axis lathe to our BobCad V38. I’ve been using BobCad Mill for almost 20 years, but this is the first time I’ve had the lathe addon. I’m trying to use canned cycles for rough turning/boring/facing and I like to use machine tool nose radius compensation. I cannot get bobcad to post the G41/G42 commands in any rough cycle. I thought it might be a lead problem like when milling if you use the wrong lead cutter comp won’t turn on, but I’ve played with everything I can think of so far and I cannot get comp to post. Any suggestions? I’m using the Haas_2x_Lathe post processor.
Thank You
