V38 Advanced Rough: Feed out of Pocket when should be Rapid
Hi All,
I’m still new to V38, I came from V30, so I have a bit of a learning curve here. I made an Advanced Rough with Adaptive Step Over for a 3D pocket. When the cutter lifts up out of the pocket to reposition to the next start point it feeds out using the Z feed rate instead of rapid. Does anyone know of a setting I might be missing or some way to change this?
Thanks,
Maybe put up a screen shot of the model, I would like to replicate the model and see if I have the same problem, I use V38 every day and don’t recall seeing this behaviour.
Hi Bazzer,
Thanks for the reply. The OD is 1.910". The ID is .875", is .530 deep, and has a .175" x 45 degree chamfer around the top. The goal is to rough out the pocket then come up and step rough the chamfer. I wanted to post the Feature file, but the forum doesn’t accept .bcom files. I used the official bobcad Haas_3x_Mill.BCPst post processor to make the Gcode I posted below, but it happens with all of my Haas post processors. When you look through the code you’ll see that the tool will be Z-.5167 deep then it will feed up to Z0.2033. Then it does similar moves with each Z step of the part.
O0100
( DATE - THU. 02/05/2026 )
( TIME - 08:21AM )
G20
G00 G17 G40 G49 G80 G90 G94 G187
G53 Z0.
G53 Y0.
(ROUGH POCKET - ADV RGH POCKET)
( FIRST CUT - FIRST TOOL)
N01 T5 M06 (1/2" 4 FLUTE YETI GMRF12RS4015WTFWF)
T5
G54 G90
G00 X0.125 Y0. S2291 M03
G43 H5 Z1.0625
M08
Z0.4625
Z0.2033
G01 G94 Z0.1033 F6.6463
G00 Z0.2033
G01 Z0.0033 F6.6463
G00 Z0.2033
Z0.1033
G01 Z-0.0967 F6.6463
G00 Z0.2033
Z0.0033
G01 Z-0.1967 F6.6463
G00 Z0.2033
Z-0.0967
G01 Z-0.2967 F6.6463
G00 Z0.2033
Z-0.1967
G01 Z-0.3967 F6.6463
G00 Z0.2033
Z-0.2967
G01 Z-0.4967 F6.6463
G00 Z0.2033
Z-0.3967
G01 Z-0.5167 F6.6463
X0.1249 Y0.005 F13.2926
X0.1246 Y0.01
X0.1241 Y0.015
X0.1234 Y0.0199
X0.1226 Y0.0248
X0.1215 Y0.0297
X0.1202 Y0.0346
X0.1187 Y0.0393
X0.1171 Y0.0441
X0.1152 Y0.0487
X0.1132 Y0.0533
X0.111 Y0.0578
X0.1086 Y0.0622
X0.106 Y0.0665
X0.1033 Y0.0707
X0.1004 Y0.0747
X0.0974 Y0.0787
X0.0941 Y0.0825
X0.0908 Y0.0862
X0.0873 Y0.0898
X0.0836 Y0.0932
X0.0798 Y0.0965
X0.0759 Y0.0996
X0.0719 Y0.1026
X0.0677 Y0.1054
X0.0635 Y0.108
X0.0591 Y0.1105
X0.0547 Y0.1128
X0.0501 Y0.1149
X0.0455 Y0.1168
X0.0408 Y0.1185
X0.036 Y0.1201
X0.0312 Y0.1214
X0.0263 Y0.1226
X0.0214 Y0.1235
X0.0165 Y0.1243
X0.0115 Y0.1249
X0.0065 Y0.1253
X0.0015 Y0.1254
X-0.0035
X-0.0085 Y0.1252
X-0.0135 Y0.1247
X-0.0185 Y0.1241
X-0.0234 Y0.1233
X-0.0283 Y0.1223
X-0.0332 Y0.121
X-0.038 Y0.1196
X-0.0427 Y0.118
X-0.0474 Y0.1162
X-0.052 Y0.1143
X-0.0565 Y0.1121
X-0.061 Y0.1098
X-0.0653 Y0.1073
X-0.0695 Y0.1046
X-0.0737 Y0.1017
X-0.0777 Y0.0987
X-0.0816 Y0.0956
X-0.0853 Y0.0922
X-0.0889 Y0.0888
X-0.0924 Y0.0852
X-0.0957 Y0.0814
X-0.0989 Y0.0775
X-0.1019 Y0.0735
X-0.1048 Y0.0694
X-0.1075 Y0.0652
X-0.11 Y0.0609
X-0.1124 Y0.0564
X-0.1145 Y0.0519
X-0.1165 Y0.0473
X-0.1183 Y0.0426
X-0.12 Y0.0379
X-0.1214 Y0.0331
X-0.1226 Y0.0282
X-0.1236 Y0.0233
X-0.1245 Y0.0183
X-0.1251 Y0.0134
X-0.1256 Y0.0084
X-0.1258 Y0.0034
Y-0.0017
X-0.1257 Y-0.0067
X-0.1254 Y-0.0117
X-0.1248 Y-0.0167
X-0.1241 Y-0.0216
X-0.1231 Y-0.0266
X-0.122 Y-0.0314
X-0.1206 Y-0.0363
X-0.1191 Y-0.0411
X-0.1174 Y-0.0458
X-0.1155 Y-0.0504
X-0.1134 Y-0.055
X-0.1111 Y-0.0595
X-0.1087 Y-0.0638
X-0.106 Y-0.0681
X-0.1032 Y-0.0723
X-0.1003 Y-0.0764
X-0.0972 Y-0.0803
X-0.0939 Y-0.0841
X-0.0905 Y-0.0878
X-0.0869 Y-0.0913
X-0.0832 Y-0.0947
X-0.0794 Y-0.098
X-0.0755 Y-0.1011
X-0.0714 Y-0.104
X-0.0672 Y-0.1068
X-0.0629 Y-0.1094
X-0.0585 Y-0.1118
X-0.054 Y-0.1141
X-0.0494 Y-0.1161
X-0.0448 Y-0.118
X-0.04 Y-0.1197
X-0.0352 Y-0.1212
X-0.0304 Y-0.1225
X-0.0255 Y-0.1237
X-0.0206 Y-0.1246
X-0.0156 Y-0.1253
X-0.0106 Y-0.1258
X-0.0056 Y-0.1262
X-0.0005 Y-0.1263
X0.0045 Y-0.1262
X0.0095 Y-0.126
X0.0145 Y-0.1255
X0.0195 Y-0.1248
X0.0244 Y-0.124
X0.0294 Y-0.1233
X0.0345 Y-0.1225
X0.0395 Y-0.1215
X0.0445 Y-0.1204
X0.0495 Y-0.1192
X0.0546 Y-0.1182
X0.0596 Y-0.1168
X0.0647 Y-0.1154
X0.0699 Y-0.1139
X0.075 Y-0.1122
X0.0801 Y-0.1103
X0.0851 Y-0.1082
X0.09 Y-0.1059
X0.0949 Y-0.1034
X0.0997 Y-0.1007
X0.1044 Y-0.0977
X0.109 Y-0.0946
X0.1135 Y-0.0913
X0.1179 Y-0.0878
X0.1221 Y-0.0841
X0.1262 Y-0.0802
X0.1302 Y-0.0762
X0.134 Y-0.072
X0.1377 Y-0.0676
X0.1412 Y-0.0631
X0.1446 Y-0.0585
X0.1478 Y-0.0537
X0.1508 Y-0.0487
X0.1537 Y-0.0437
X0.1563 Y-0.0385
X0.1588 Y-0.0332
X0.1611 Y-0.0278
X0.1632 Y-0.0223
X0.165 Y-0.0166
X0.1665 Y-0.011
X0.1679 Y-0.0052
X0.169 Y0.0006
X0.1698 Y0.0065
X0.1703 Y0.0124
X0.1708 Y0.0183
Y0.0243
X0.1705 Y0.0302
X0.17 Y0.0361
X0.1693 Y0.042
X0.1684 Y0.0479
X0.1671 Y0.0537
X0.1659 Y0.0596
X0.1642 Y0.0653
X0.162 Y0.0708
X0.158 Y0.0804
X0.1575 Y0.0814
X0.156 Y0.0844
X0.1528 Y0.0899
X0.1503 Y0.0939
X0.138 Y0.111
X0.1357 Y0.1141
X0.133 Y0.117
X0.117 Y0.133
X0.1141 Y0.1357
X0.111 Y0.138
X0.0939 Y0.1503
X0.0899 Y0.1528
X0.0844 Y0.156
X0.0814 Y0.1575
X0.0724 Y0.1618
X0.0681 Y0.1636
X0.0516 Y0.1696
X0.0457 Y0.1713
X0.0298 Y0.1747
X0.0242 Y0.1756
X0.0083 Y0.177
X0.0039 Y0.1772
X0.0026
X-0.0132 Y0.1768
X-0.0191 Y0.1762
X-0.0349 Y0.1737
X-0.0406 Y0.1725
X-0.0565 Y0.1679
X-0.0622 Y0.1659
X-0.0787 Y0.1588
X-0.0818 Y0.1573
X-0.0848 Y0.1556
X-0.1005 Y0.146
X-0.1047 Y0.143
X-0.1134 Y0.1363
X-0.1162 Y0.1339
X-0.1228 Y0.1279
X-0.1257 Y0.125
X-0.1347 Y0.1152
X-0.1376 Y0.1118
X-0.1449 Y0.1021
X-0.1469 Y0.0993
X-0.1504 Y0.0939
X-0.1528 Y0.0898
X-0.1617 Y0.0724
X-0.1637 Y0.068
X-0.167 Y0.0596
X-0.168 Y0.0568
X-0.1699 Y0.0508
X-0.1711 Y0.0465
X-0.1747 Y0.0298
X-0.1756 Y0.0242
X-0.177 Y0.0083
X-0.1772 Y0.0039
Y0.0026
X-0.1768 Y-0.0132
X-0.1762 Y-0.0191
X-0.1737 Y-0.0351
X-0.1725 Y-0.0405
X-0.1683 Y-0.0556
X-0.1662 Y-0.0615
X-0.159 Y-0.0782
X-0.1562 Y-0.0838
X-0.1471 Y-0.0988
X-0.1451 Y-0.1019
X-0.1429 Y-0.1048
X-0.1282 Y-0.1223
X-0.1254 Y-0.1254
X-0.1223 Y-0.1282
X-0.1048 Y-0.1429
X-0.1019 Y-0.1451
X-0.0988 Y-0.1471
X-0.0838 Y-0.1562
X-0.0782 Y-0.159
X-0.0615 Y-0.1662
X-0.0556 Y-0.1683
X-0.0405 Y-0.1725
X-0.0351 Y-0.1737
X-0.0191 Y-0.1762
X-0.0132 Y-0.1768
X0.0026 Y-0.1772
X0.0039
X0.0083 Y-0.177
X0.0242 Y-0.1756
X0.0298 Y-0.1747
X0.0465 Y-0.1711
X0.0508 Y-0.1699
X0.0568 Y-0.168
X0.0596 Y-0.167
X0.068 Y-0.1637
X0.0724 Y-0.1617
X0.0898 Y-0.1528
X0.0939 Y-0.1504
X0.0993 Y-0.1469
X0.1021 Y-0.1449
X0.1118 Y-0.1376
X0.1152 Y-0.1347
X0.125 Y-0.1257
X0.1279 Y-0.1228
X0.1339 Y-0.1162
X0.1363 Y-0.1134
X0.143 Y-0.1047
X0.146 Y-0.1005
X0.1556 Y-0.0848
X0.1573 Y-0.0818
X0.1588 Y-0.0787
X0.1659 Y-0.0622
X0.1679 Y-0.0565
X0.1725 Y-0.0406
X0.1737 Y-0.0349
X0.1762 Y-0.0191
X0.1768 Y-0.0132
X0.1772 Y0.0026
Y0.0039
X0.177 Y0.0083
X0.1756 Y0.0242
X0.1747 Y0.0298
X0.1713 Y0.0457
X0.1696 Y0.0516
X0.1636 Y0.0681
X0.1618 Y0.0724
X0.1575 Y0.0814
X0.1555 Y0.0846
X0.1531 Y0.0876
X0.1505 Y0.0904
X0.1477 Y0.0929
X0.1446 Y0.0951
X0.1413 Y0.097
X0.1378 Y0.0987
X0.1342 Y0.0999
X0.1305 Y0.1009
X0.1268 Y0.1015
X0.123 Y0.1017
X0.1192 Y0.1015
X0.1154 Y0.1011
X0.1117 Y0.1002
X0.1081 Y0.099
X0.1046 Y0.0975
X0.1012 Y0.0956
X0.0981 Y0.0935
X0.0952 Y0.0911
X0.0251 Y0.0267
Z0.2033 F6.6463
G00 Z0.4625
G01 X0.1337 Y-0.0175 F600.
G00 Z-0.055
G01 Z-0.155 F6.6463
X0.1585 Y-0.0048 F13.2926
X0.1612 Y-0.0033
X0.1637 Y-0.0016
X0.1661 Y0.0004
X0.1683 Y0.0025
X0.1819 Y0.0169
X0.1883 Y0.0294
X0.1918 Y0.0429
X0.1917 Y0.0569
X0.1885 Y0.0706
X0.1873 Y0.075
X0.1807 Y0.0903
X0.1791 Y0.0935
X0.1777 Y0.0959
X0.1681 Y0.1118
X0.1658 Y0.1152
X0.158 Y0.1258
X0.1554 Y0.1289
X0.151 Y0.134
X0.1489 Y0.1362
X0.1362 Y0.1489
X0.134 Y0.151
X0.1289 Y0.1554
X0.1258 Y0.158
X0.1152 Y0.1658
X0.1118 Y0.1681
X0.0959 Y0.1777
X0.0936 Y0.179
X0.0903 Y0.1807
X0.0727 Y0.1883
X0.0678 Y0.1902
X0.0511 Y0.1953
X0.0461 Y0.1966
X0.0296 Y0.1998
X0.0244 Y0.2005
X0.0079 Y0.2018
X0.0042 Y0.2019
X0.003
X-0.0142 Y0.2014
X-0.0182 Y0.2012
X-0.0272 Y0.2002
X-0.0296 Y0.1998
X-0.0359 Y0.1988
X-0.0397 Y0.198
X-0.057 Y0.1937
X-0.0619 Y0.1922
X-0.079 Y0.1858
X-0.0831 Y0.1841
X-0.0934 Y0.179
X-0.096 Y0.1777
X-0.1009 Y0.1749
X-0.1044 Y0.1728
X-0.1227 Y0.1603
X-0.1258 Y0.1579
X-0.1261 Y0.1577
X-0.1283 Y0.1558
X-0.1447 Y0.1407
X-0.1471 Y0.1383
X-0.1487 Y0.1366
X-0.1513 Y0.1336
X-0.1653 Y0.1157
X-0.169 Y0.1104
X-0.1785 Y0.0942
X-0.1809 Y0.0895
X-0.1883 Y0.0728
X-0.1902 Y0.0677
X-0.1953 Y0.0511
X-0.1965 Y0.0461
X-0.1997 Y0.0296
X-0.2004 Y0.0245
X-0.2018 Y0.0079
X-0.2019 Y0.0042
Y0.0029
X-0.2015 Y-0.0136
X-0.201 Y-0.0187
X-0.1988 Y-0.0353
X-0.1978 Y-0.0403
X-0.1935 Y-0.0575
X-0.1924 Y-0.0613
X-0.1896 Y-0.0695
X-0.1886 Y-0.0722
X-0.1858 Y-0.0792
X-0.1841 Y-0.0829
X-0.1748 Y-0.101
X-0.1729 Y-0.1043
X-0.1685 Y-0.1113
X-0.1665 Y-0.1143
X-0.1601 Y-0.1229
X-0.158 Y-0.1256
X-0.1471 Y-0.1383
X-0.1447 Y-0.1409
X-0.1409 Y-0.1447
X-0.1383 Y-0.1471
X-0.1256 Y-0.158
X-0.1229 Y-0.1601
X-0.1143 Y-0.1665
X-0.1113 Y-0.1685
X-0.1043 Y-0.1729
X-0.101 Y-0.1748
X-0.0829 Y-0.1841
X-0.0792 Y-0.1858
X-0.0722 Y-0.1886
X-0.0695 Y-0.1896
X-0.0613 Y-0.1924
X-0.0575 Y-0.1935
X-0.0403 Y-0.1978
X-0.0353 Y-0.1988
X-0.0187 Y-0.201
X-0.0136 Y-0.2015
X0.0029 Y-0.2019
X0.0042
X0.0079 Y-0.2018
X0.0245 Y-0.2004
X0.0296 Y-0.1997
X0.0461 Y-0.1965
X0.0511 Y-0.1953
X0.0677 Y-0.1902
X0.0728 Y-0.1883
X0.0895 Y-0.1809
X0.0942 Y-0.1785
X0.1104 Y-0.169
X0.1157 Y-0.1653
X0.1336 Y-0.1513
X0.1366 Y-0.1487
X0.1383 Y-0.1471
X0.1407 Y-0.1447
X0.1558 Y-0.1283
X0.1577 Y-0.1261
X0.1579 Y-0.1258
X0.1603 Y-0.1227
X0.1728 Y-0.1044
X0.1749 Y-0.1009
X0.1777 Y-0.096
X0.179 Y-0.0934
X0.1841 Y-0.0831
X0.1858 Y-0.079
X0.1922 Y-0.0619
X0.1937 Y-0.057
X0.198 Y-0.0397
X0.1988 Y-0.0359
X0.1998 Y-0.0296
X0.2002 Y-0.0272
X0.2012 Y-0.0182
X0.2014 Y-0.0142
X0.2019 Y0.003
Y0.0042
X0.2018 Y0.0079
X0.2005 Y0.0244
X0.1998 Y0.0296
X0.1966 Y0.0461
X0.1953 Y0.0511
X0.1902 Y0.0678
X0.1883 Y0.0727
X0.1827 Y0.0855
X0.1809 Y0.0891
X0.1788 Y0.0925
X0.1764 Y0.0956
X0.1737 Y0.0985
X0.1707 Y0.1011
X0.1674 Y0.1034
X0.164 Y0.1054
X0.1603 Y0.107
X0.1566 Y0.1083
X0.1527 Y0.1091
X0.1487 Y0.1096
X0.1448 Y0.1097
X0.1408 Y0.1095
X0.1369 Y0.1088
X0.133 Y0.1077
X0.1293 Y0.1063
X0.1258 Y0.1045
X0.1224 Y0.1024
X0.1193 Y0.0999
X0.1164 Y0.0972
X0.0534 Y0.0308
Z-0.055 F6.6463
G00 Z0.4625
G01 X0.1397 Y-0.0537 F600.
G00 Z-0.0033
G01 Z-0.1033 F6.6463
X0.1938 Y0.0002 F13.2926
X0.1963 Y0.0029
X0.2088 Y0.0182
X0.2153 Y0.0307
X0.2202 Y0.0438
X0.2225 Y0.0582
X0.2227 Y0.0796
X0.2198 Y0.1009
X0.2151 Y0.1184
X0.208 Y0.1367
X0.1987 Y0.1547
X0.1935 Y0.1634
X0.1814 Y0.1772
X0.1772 Y0.1814
X0.1584 Y0.198
X0.1544 Y0.2012
X0.1367 Y0.2136
X0.1336 Y0.2156
X0.1243 Y0.2211
X0.1223 Y0.2222
X0.115 Y0.2261
X0.1121 Y0.2275
X0.0939 Y0.2356
X0.0899 Y0.2372
X0.0723 Y0.2431
X0.0682 Y0.2443
X0.0506 Y0.2485
X0.0467 Y0.2493
X0.029 Y0.2519
X0.025 Y0.2524
X0.0074 Y0.2535
X0.0044 Y0.2536
X0.0034
X-0.0142 Y0.2532
X-0.0182 Y0.253
X-0.0358 Y0.2511
X-0.0398 Y0.2505
X-0.0578 Y0.247
X-0.0611 Y0.2462
X-0.071 Y0.2435
X-0.0728 Y0.243
X-0.0795 Y0.2409
X-0.0826 Y0.2398
X-0.1007 Y0.2327
X-0.1046 Y0.231
X-0.1218 Y0.2224
X-0.1259 Y0.2201
X-0.1444 Y0.2084
X-0.1474 Y0.2064
X-0.155 Y0.2008
X-0.1569 Y0.1993
X-0.1664 Y0.1914
X-0.1687 Y0.1894
X-0.1793 Y0.1794
X-0.1813 Y0.1774
X-0.1882 Y0.1701
X-0.1901 Y0.1679
X-0.1984 Y0.158
X-0.2003 Y0.1555
X-0.21 Y0.1421
X-0.2115 Y0.14
X-0.2139 Y0.1363
X-0.2153 Y0.134
X-0.226 Y0.1151
X-0.2276 Y0.1119
X-0.232 Y0.1025
X-0.2328 Y0.1007
X-0.2358 Y0.0934
X-0.237 Y0.0904
X-0.2431 Y0.0723
X-0.2443 Y0.0682
X-0.2485 Y0.0506
X-0.2493 Y0.0467
X-0.2519 Y0.029
X-0.2524 Y0.0251
X-0.2535 Y0.0074
X-0.2536 Y0.0044
Y0.0034
X-0.2532 Y-0.0142
X-0.253 Y-0.0182
X-0.2511 Y-0.0358
X-0.2505 Y-0.0398
X-0.247 Y-0.0574
X-0.2461 Y-0.0614
X-0.241 Y-0.079
X-0.2396 Y-0.0831
X-0.2328 Y-0.1007
X-0.231 Y-0.1046
X-0.222 Y-0.1225
X-0.2201 Y-0.126
X-0.2115 Y-0.14
X-0.2101 Y-0.1421
X-0.2083 Y-0.1447
X-0.2066 Y-0.1471
X-0.1914 Y-0.1664
X-0.1877 Y-0.1705
X-0.1705 Y-0.1877
X-0.1664 Y-0.1914
X-0.1471 Y-0.2066
X-0.1447 Y-0.2083
X-0.1421 Y-0.2101
X-0.14 Y-0.2115
X-0.126 Y-0.2201
X-0.1225 Y-0.222
X-0.1046 Y-0.231
X-0.1007 Y-0.2328
X-0.0831 Y-0.2396
X-0.079 Y-0.241
X-0.0614 Y-0.2461
X-0.0574 Y-0.247
X-0.0398 Y-0.2505
X-0.0358 Y-0.2511
X-0.0182 Y-0.253
X-0.0142 Y-0.2532
X0.0034 Y-0.2536
X0.0044
X0.0074 Y-0.2535
X0.0251 Y-0.2524
X0.029 Y-0.2519
X0.0467 Y-0.2493
X0.0506 Y-0.2485
X0.0682 Y-0.2443
X0.0723 Y-0.2431
X0.0904 Y-0.237
X0.0934 Y-0.2358
X0.1007 Y-0.2328
X0.1025 Y-0.232
X0.1119 Y-0.2276
X0.1151 Y-0.226
X0.134 Y-0.2153
X0.1363 Y-0.2139
X0.14 Y-0.2115
X0.1421 Y-0.21
X0.1555 Y-0.2003
X0.158 Y-0.1984
X0.1679 Y-0.1901
X0.1701 Y-0.1882
X0.1774 Y-0.1813
X0.1794 Y-0.1793
X0.1894 Y-0.1687
X0.1914 Y-0.1664
X0.1993 Y-0.1569
X0.2008 Y-0.155
X0.2064 Y-0.1474
X0.2084 Y-0.1444
X0.2201 Y-0.1259
X0.2224 Y-0.1218
X0.231 Y-0.1046
X0.2327 Y-0.1007
X0.2398 Y-0.0826
X0.2409 Y-0.0795
X0.243 Y-0.0728
X0.2435 Y-0.071
X0.2462 Y-0.0611
X0.247 Y-0.0578
X0.2505 Y-0.0398
X0.2511 Y-0.0358
X0.253 Y-0.0182
X0.2532 Y-0.0142
X0.2536 Y0.0034
Y0.0044
X0.2535 Y0.0074
X0.2524 Y0.025
X0.2519 Y0.029
X0.2493 Y0.0467
X0.2485 Y0.0506
X0.2443 Y0.0682
X0.2431 Y0.0723
X0.2372 Y0.0899
X0.2356 Y0.0939
X0.2275 Y0.1121
X0.2261 Y0.115
X0.2222 Y0.1223
X0.2211 Y0.1243
X0.2156 Y0.1336
X0.2136 Y0.1367
X0.2012 Y0.1544
X0.198 Y0.1584
X0.1887 Y0.1689
X0.186 Y0.1718
X0.1829 Y0.1743
X0.1796 Y0.1766
X0.1762 Y0.1785
X0.1725 Y0.1801
X0.1687 Y0.1813
X0.1648 Y0.1821
X0.1609 Y0.1825
X0.1569
X0.1529 Y0.1822
X0.149 Y0.1815
X0.1452 Y0.1804
X0.1415 Y0.1789
X0.138 Y0.1771
X0.1347 Y0.1749
X0.1316 Y0.1724
X0.1287 Y0.1696
X0.1262 Y0.1666
X0.1239 Y0.1633
X0.0756 Y0.0842
Z-0.0033 F6.6463
G00 Z0.4625
G01 X-0.0338 Y-0.1029 F600.
G00 Z0.0483
G01 Z-0.0517 F6.6463
X-0.0115 Y-0.2167 F13.2926
X-0.0107 Y-0.2202
X-0.0095 Y-0.2236
X-0.0081 Y-0.2269
X-0.0063 Y-0.2301
X-0.0043 Y-0.233
X-0.0021 Y-0.2358
X0.0004 Y-0.2384
X0.0032 Y-0.2407
X0.0187 Y-0.253
X0.0298 Y-0.2615
X0.0459 Y-0.2684
X0.0652 Y-0.2728
X0.0811 Y-0.2745
X0.0992 Y-0.2742
X0.1197 Y-0.2715
X0.1369 Y-0.2675
X0.1551 Y-0.2614
X0.1609 Y-0.2593
X0.1683 Y-0.2546
X0.1702 Y-0.2534
X0.1774 Y-0.2484
X0.1794 Y-0.2469
X0.1971 Y-0.233
X0.1986 Y-0.2318
X0.199 Y-0.2314
X0.201 Y-0.2297
X0.2196 Y-0.212
X0.2227 Y-0.2087
X0.2388 Y-0.1901
X0.2403 Y-0.1882
X0.2426 Y-0.1852
X0.2439 Y-0.1835
X0.2544 Y-0.1687
X0.2559 Y-0.1664
X0.2642 Y-0.153
X0.2655 Y-0.1507
X0.2677 Y-0.1468
X0.2686 Y-0.1451
X0.2781 Y-0.1258
X0.2795 Y-0.1227
X0.2862 Y-0.1062
X0.2868 Y-0.1046
X0.2872 Y-0.1037
X0.2878 Y-0.1017
X0.2939 Y-0.0828
X0.2948 Y-0.0793
X0.2991 Y-0.0611
X0.2998 Y-0.0578
X0.3027 Y-0.0395
X0.3031 Y-0.0362
X0.3048 Y-0.0179
X0.305 Y-0.0145
X0.3053 Y0.0038
Y0.0046
X0.3052 Y0.007
X0.3043 Y0.0253
X0.304 Y0.0288
X0.3016 Y0.0471
X0.3011 Y0.0502
X0.2975 Y0.0686
X0.2967 Y0.072
X0.2915 Y0.0906
X0.2907 Y0.0932
X0.2868 Y0.1047
X0.2863 Y0.106
X0.284 Y0.1122
X0.2829 Y0.1149
X0.2744 Y0.1337
X0.273 Y0.1366
X0.2652 Y0.1512
X0.2646 Y0.1521
X0.2628 Y0.1555
X0.2611 Y0.1581
X0.2486 Y0.1772
X0.2469 Y0.1796
X0.2438 Y0.1837
X0.2427 Y0.1851
X0.2315 Y0.199
X0.2297 Y0.201
X0.2224 Y0.2091
X0.2209 Y0.2107
X0.2107 Y0.2209
X0.2091 Y0.2224
X0.201 Y0.2297
X0.199 Y0.2315
X0.1851 Y0.2427
X0.1837 Y0.2438
X0.1796 Y0.2469
X0.1772 Y0.2486
X0.1581 Y0.2611
X0.1555 Y0.2628
X0.1521 Y0.2646
X0.1512 Y0.2652
X0.1366 Y0.273
X0.1337 Y0.2744
X0.1149 Y0.2829
X0.1122 Y0.284
X0.106 Y0.2863
X0.1047 Y0.2868
X0.0932 Y0.2907
X0.0906 Y0.2915
X0.072 Y0.2967
X0.0686 Y0.2975
X0.0502 Y0.3011
X0.0471 Y0.3016
X0.0288 Y0.304
X0.0253 Y0.3043
X0.007 Y0.3052
X0.0046 Y0.3053
X0.0038
X-0.0145 Y0.305
X-0.0179 Y0.3048
X-0.0362 Y0.3031
X-0.0395 Y0.3027
X-0.0578 Y0.2998
X-0.0611 Y0.2991
X-0.0793 Y0.2948
X-0.0828 Y0.2939
X-0.1017 Y0.2878
X-0.1037 Y0.2872
X-0.1046 Y0.2868
X-0.1062 Y0.2862
X-0.1227 Y0.2795
X-0.1258 Y0.2781
X-0.1451 Y0.2686
X-0.1468 Y0.2677
X-0.1507 Y0.2655
X-0.153 Y0.2642
X-0.1664 Y0.2559
X-0.1687 Y0.2544
X-0.1835 Y0.2439
X-0.1852 Y0.2426
X-0.1882 Y0.2403
X-0.1901 Y0.2388
X-0.2087 Y0.2227
X-0.212 Y0.2196
X-0.2297 Y0.201
X-0.2314 Y0.199
X-0.2318 Y0.1986
X-0.233 Y0.1971
X-0.2469 Y0.1794
X-0.2484 Y0.1774
X-0.2534 Y0.1702
X-0.2546 Y0.1683
X-0.2611 Y0.158
X-0.2626 Y0.1555
X-0.2732 Y0.1361
X-0.2742 Y0.1342
X-0.2752 Y0.1321
X-0.2761 Y0.1303
X-0.2828 Y0.115
X-0.2839 Y0.112
X-0.2906 Y0.0935
X-0.2916 Y0.0903
X-0.2967 Y0.0721
X-0.2975 Y0.0685
X-0.3011 Y0.0502
X-0.3016 Y0.0471
X-0.304 Y0.0288
X-0.3043 Y0.0252
X-0.3052 Y0.007
X-0.3053 Y0.0046
Y0.0038
X-0.305 Y-0.0145
X-0.3048 Y-0.0179
X-0.3031 Y-0.0362
X-0.3027 Y-0.0395
X-0.2997 Y-0.0583
X-0.2993 Y-0.0606
X-0.2975 Y-0.0687
X-0.297 Y-0.0707
X-0.2947 Y-0.0799
X-0.294 Y-0.0823
X-0.2881 Y-0.101
X-0.2869 Y-0.1043
X-0.2794 Y-0.123
X-0.2783 Y-0.1256
X-0.276 Y-0.1305
X-0.2754 Y-0.1318
X-0.2689 Y-0.1445
X-0.2673 Y-0.1473
X-0.256 Y-0.1664
X-0.2545 Y-0.1687
X-0.2536 Y-0.17
X-0.2405 Y-0.188
X-0.2387 Y-0.1903
X-0.2331 Y-0.1971
X-0.2318 Y-0.1987
X-0.2217 Y-0.2099
X-0.2199 Y-0.2117
X-0.2117 Y-0.2199
X-0.2099 Y-0.2217
X-0.1987 Y-0.2318
X-0.1971 Y-0.2331
X-0.1903 Y-0.2387
X-0.188 Y-0.2405
X-0.17 Y-0.2536
X-0.1687 Y-0.2545
X-0.1664 Y-0.256
X-0.1473 Y-0.2673
X-0.1445 Y-0.2689
X-0.1318 Y-0.2754
X-0.1305 Y-0.276
X-0.1256 Y-0.2783
X-0.123 Y-0.2794
X-0.1043 Y-0.2869
X-0.101 Y-0.2881
X-0.0823 Y-0.294
X-0.0799 Y-0.2947
X-0.0707 Y-0.297
X-0.0687 Y-0.2975
X-0.0606 Y-0.2993
X-0.0583 Y-0.2997
X-0.0395 Y-0.3027
X-0.0362 Y-0.3031
X-0.0179 Y-0.3048
X-0.0145 Y-0.305
X0.0038 Y-0.3053
X0.0046
X0.007 Y-0.3052
X0.0252 Y-0.3043
X0.0288 Y-0.304
X0.0471 Y-0.3016
X0.0502 Y-0.3011
X0.0685 Y-0.2975
X0.0721 Y-0.2967
X0.0903 Y-0.2916
X0.0935 Y-0.2906
X0.112 Y-0.2839
X0.115 Y-0.2828
X0.1303 Y-0.2761
X0.1321 Y-0.2752
X0.1342 Y-0.2742
X0.1361 Y-0.2732
X0.1555 Y-0.2626
X0.158 Y-0.2611
X0.1683 Y-0.2546
X0.1713 Y-0.2523
X0.1741 Y-0.2496
X0.1766 Y-0.2466
X0.1788 Y-0.2435
X0.1807 Y-0.2401
X0.1823 Y-0.2366
X0.1835 Y-0.233
X0.1844 Y-0.2292
X0.1849 Y-0.2254
X0.1851 Y-0.2216
X0.1849 Y-0.2177
X0.1843 Y-0.2139
X0.1834 Y-0.2102
X0.1821 Y-0.2066
X0.1805 Y-0.2031
X0.1785 Y-0.1997
X0.1762 Y-0.1966
X0.1737 Y-0.1937
X0.1709 Y-0.1911
X0.1003 Y-0.131
Z0.0483 F6.6463
G00 Z0.4625
Z1.0625
M09
M05
G53 Z0.
G53 Y0.
T5 M06
M30
Screenshot 2026-02-05 081515
