I have beta tested years ago and this bug has always been there. Bobcad’s coreless feature uses the same routine as 2D pocketing. The trouble is that it creates drops in almost all attempts. Any shape other than a round hole create drops that can and many cases will either scrap your part or damage the lower nozzle.
Bobcad support has blown it off and even suggested not to attempt using the feature for ‘irregular shapes’. Well an oblong hole (key slot) is not far off from a regular shape. Small drops can cause huge issues. I even suggested they use the 3D path to cut from center out as a means to create a true coreless cut.
For more than a decade I have reported this issue. Always the promise that it may be fixed in the next release. I am now at my wits end and it cost us thousands of dollars in the latest scrap and down time. I may even have to switch to a new software due to this issue. In other words the lack of caring about long term bugs is about to cost them a long term customer.
