Yeah i can definitely see the toolpath issue at my end too. Not sure what caused the issue at the moment. , we will look into it.
- Posted a Wire program, and it looked like everything was scaled down to metric.
For the posted code coordinates showing in metric occasionally, we have fixed this issue already and fix will be available in the coming V34 SP1. For the moment, you can do this to work around the problem. Open the post you are using by expanding the machine for the job and selecting the post and open it in notepad or notepad++ whichever text editor you are using.
Scroll down in your post processor to post question number 213. and change the value from E after “?” to S and save the post, close the file and then post the code.
What you are doing here is essentially asking the post processor to use the system unit set in your bbcd file which you can see in the status bar down at the right bottom.
This way the posted code will be using the same unit in the bbcd file.
- Again in a WIre program, was creating a 5 pass cut on multiple pockets.
Not aware of the 5 cuts looking like 25 passes, some more info on this issue will be helpful
- I have the directory set to where BobCAD saves new posts as a different one than the default directory
I am confused a bit when you say “saves new posts” - are you talking about the nc file (.nc) or the actual post processor itself (.EDMPST). If you look at your job current settings, you will see the filepath where the posts are and the nc filepath is where the nc files gets saved to. Like i have shown in this screenshot below which is from the job level current settings, the filepath displayed there is where the nc files gets saved automatically. This is typically in your BoBCAD Vxx data folder → NC → Wire EDM folder
if you want to change the default filepath, you must do so from the CAM defaults, select your machine and set the right filepath there.
Changing the path at job level will only affect the particular job, while changing from CAM defaults current settings will save the filepath with the machine itself, so every time you create a new job using that machine, nc files will be saved there
